UnclThan Oct 23, 2021 2 0 10 Oct 23, 2021 #1 processor: i3-2120 (3.30GHz) Ram: 6 GB Motherboard: FOXCONN 17A0 PSU: 300w (I'm think of buying a 400w) is my motherboard and processor compatible for gtx 600 or 700 series? ( zotac gtx 650 ) Last edited: Oct 23, 2021
dotas1 Splendid Dec 5, 2015 3,156 513 24,540 Oct 23, 2021 #2 The motherboard has the appropriate slot. After that if the GPU fits in the case and if you have the PSU that can handle said GPU, you are good to go. Reactions: UnclThan Upvote 0 Downvote
UnclThan Oct 23, 2021 2 0 10 Oct 23, 2021 #3 dotas1 said: The motherboard has the appropriate slot. After that if the GPU fits in the case and if you have the PSU that can handle said GPU, you are good to go. Click to expand... idk if my 300 watts psu can handle it Upvote 0 Downvote
dotas1 Splendid Dec 5, 2015 3,156 513 24,540 Oct 23, 2021 #4 Make and model of it? You can also take a picture, upload it to imgur and paste the link here. Upvote 0 Downvote
