Which lap top is better for mathematical modelling?
YoungUser
6
I am plannning to purchase a Mac Book Pro and there is a noticeable priced dfifference between the Core i5 Mac Book Pro versus the Core i7 version (2.5GHz vs 2.8Ghz) with about a $350 difference. I plan to use it only for general email, microsoft applications, Mathlab, Labview applications. Which would you recommend and why? I am just trying to understand if I should pay that difference or use that $$ and upgrade my DRAM instead. Thanks in advance.
Currently, the $350 difference is based on the following tech specs:
Mac BookPro Core i7
2.8 GHz Dual-Core Intel Core i7 Processor
4 GB 1333MHz DDR3 SDRAM
750GB 5400rpm Hard Drive; 8x DVD/CD SuperDrive
MacBook Pro Core i5
2.4 GHz Dual-Core Intel Core i5 Processor
4GB 1333MHz DDR3 SDRAM
500 GB Hard Drive, 8x DVD/CD SuperDrive
As you can see, the only difference is the Core specification and the additional 250GB SATA HD (750GB SATA HD vs 500GB SATA HD).
What do you recommend?
WR2,
Mac BookPro Core i7
MacBook Pro Core i5
What do you recommend? $200 will probaboy buy me additional 4GB 1333MHz DDR3 SDRAM making that a 8GB instead of 4GB
