Which LED lights would look better with my pc, red or white?
BenJLiu
104
I've recently decided to build my first gaming pc but I don't know if red or white LEDs would be better looking in my corsair carbide 100r windowed case.
Pc parts:https://au.pcpartpicker.com/user/Mentos7777777/saved/#view=vg7BmG
Also 2 led riing 12's will be used as intake fans and a af120 will be used as an exhaust fan.
Keep in mind that the led coloured fans and colour of the ram will be altered to suit the theme
I'd go for white, everyone and their mother has a red build.
Then again if you like red there's nothing wrong with it but I think black and white combo looks classy.
Thanks for the opinion I originally was going to pick white/black but I overreacted and thought that the rx 480 , which is red, was going to mess it i up but I guess I'll just go black/white
Any suggestions on good LED strips?
Do you know any way to stickerup, tape, paint over, the gpu without destroying the look of it and making it look weird?
it is good but not the best.
look here
http://www.pcgamer.com/the-best-rgb-led-lighting-kit/
well if it's good than I'll just buy the deepcool. Not looking for the best just looking for good affordable led strips
go for it
read about it here
http://www.deepcool.com/product/dcoolingaccessory/2016-03/12_4814.shtml
incase you want to read about the Nzext:
https://www.nzxt.com/products/hue-plus
If you have a good steady hand you could just draw over it with a marker, otherwise if you can get your sticker printed somewhere you could desaturate the logo to make it white, get a black bg and stick it right on top, that part is glossy if I recall so you could get away with it very nicely.
Or you could stick some elecrtical tape on it to cover, the lazy way 😛 (also to draw the logo yourself without touching the gpu itself perhaps)
