Which motherboard driver do I need?? So confused! Please help me!
Andrew_S_92
Hello eveyone,
As the title says, I am looking to update my Mobo drivers but I am just clueless which to get as I go to the website but there are so many.
My motherboard is a ASROCK N68c-GS FX. I type this into Google and it takes me to the appropriate site but I am not sure which driver it is I need. Will any work? Which ones should I get? I am on Windows 10 64bit.
Could someone possibly link me and tell me which one I should get?
Thank you for your help!
Andrew
Do I even need one? Would one of those windows 7 ones work or just mess things up on my Windows 10?
The board is too old, they never made official drivers after win 7. Just have to let windows 10 + Microsoft updates do it. check Microsoft updates in the optional updates you may find device drivers on offer
Does device manager have any yellow exclamation marks next to any devices, indicating no/wrong drivers?
Oh that's a shame, I hope it doesn't cause to many problems then :??:
I have looked at device manager and there are no yellow exclamation marks next to any of my devices. Is that a good thing? I hope so. Does that mean that they are all as up to date as they possibly can be?
Yep that's good, if it all runs fine there is no need to worry
