Build Advice Which one to get, Lian Li SL-INF 120 or Lian Li AL120 V2 ?
Dreadwolf91
Commendable
Jan 20, 2021
I will build a new PC on base of a Lian Li O11D Evo (or XL)
So after long time watching Youtube videos about RGB fans i found these two especially nice and they are the same price here in Germany. The SL-INF is also included in the AiO that Lian Li sells which i might consider for my new pc build which is nice for looks.
My question is: Is there a reason why i should buy the AL V2 over the SL-INF if they cost the same ? The specs look like the AL is a bit better in performance/noise but how much is that in numbers ? If its like 10%+ better i would probably go with the AL but if its just minor differences in performance/noise then id rather get the SL-INF
