[SOLVED] Which parts should i get for 1k$ Gaming pc?
TruthJake
19
Thinking about making my dad a gaming pc for Christmas since his old pc is causing him issues for awhile now and that his pc is way overdue for an upgrade.I would say 10yeas+ My max is $1,000. He usually plays games like WoW, Diablo3, and civilization. Any recommendations would be appreciated.
Take your pick between AMD RX 5700 XT and Nvidia RTX 2060 Super. Honestly though, those are a bit high-end for those games you mentioned. You could drop down to a GTX 1660, 1660 Super, or 1660 Ti and maybe get some peripherals or something else.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($185.99 @ Amazon)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard ($114.99 @ B&H)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory ($59.99 @ Newegg)
Storage: Samsung 860 Evo 1 TB 2.5" Solid State Drive ($109.99 @ Amazon)
Video Card: MSI GeForce RTX 2060 SUPER 8 GB GAMING X Video Card ($409.99 @ B&H)
Case:...
Case: Fractal Design Focus G ATX Mid Tower Case ($52.00 @ Walmart)
Power Supply: Corsair CX (2017) 650 W 80+ Bronze Certified ATX Power Supply ($64.99 @ Newegg)
Total: $997.94
Generated by PCPartPicker 2019-12-02 01:37 EST-0500
Reactions: OllympianGamer
If I were you I would buy a ryzen 7 2700x from microcenter use the stock cooler $160
(I use this cpu)
https://www.microcenter.com/product...-am4-boxed-processor-with-wraith-prism-cooler
buy the asrock b450 pro4 and the 2700x to buy it for $60 (I use this board)
https://www.microcenter.com/product/509732/asrock-b450m-pro4-am4-matx-amd-motherboard
buy this case $72
https://www.microcenter.com/product...red-glass-atx-mid-tower-computer-case---black
16gb g skill ripjaws for $60
https://www.microcenter.com/product...desktop-memory-kit-f4-3200c16d-16gvkb---black
buy BOTH of these hard drives put windows 10 on the ssd $110
https://www.microcenter.com/product...7200rpm-sata-iii-6gb-s-35-internal-hard-drive
https://www.microcenter.com/product...-sata-iii-6gb-s-25-internal-solid-state-drive
for the video card I would buy an rtx 2060 $350 (reason so much is because it is the most expensive part in most builds)
https://www.microcenter.com/product...e-rtx-2060-dual-fan-6gb-gddr6-pcie-video-card
these fans $40
https://www.microcenter.com/product...agnetic-levitation-120mm-case-fan---twin-pack
this evga 600w 80+gold psu $70
Description=evga%20modular%20psu&cm_re=evga_modular_psu--17-438-157--Product
windows 10 here $140
https://www.microcenter.com/product/610158/microsoft-microsoft-windows-10-home-32-64-bit---usb
if you do it this way you won't break the bank.
