which power supply better
degionz
81
I would like to buy new psu which is better?
Prossesor i3 4150
ram kingston 4gb x2
Graphic card gtx 750ti
mobo asus b85 pro gamer
Coolermaster or aerocool strike x?
Or got other better model?
That unit would be ok, and I mean JUST ok, as the CX, CS, VS and RM units are all pretty iffy when it comes to using them with gaming cards. I'm not sure I'd categorize the 750 TI as a gaming card, per se, but it depends on the model. Some of the 750 and 750TI cards use supplementary power, some don't. For models that do, I wouldn't use those power supplies. For the ones that don't, they may be ok for a while.
I'd really recommend the Antec VP-450 over anything else near it's price range and since it's available in most markets, it should be an option at a similar price, if not less, than the Corsair unit.
What on earth? Sirtec? Can you elaborate why the CX is that bad as you think it is? It is actually ideal for setup and desired budget. Even with a GTX 960 he would be fine with the CX.
That's a mistake, which I'll ask Dottorent to correct. It was a Tier 2 unit previously. The VP-450 was highly recommended per the hardwaresecrets review, and while the 80plus ratings are BS, with half of them being fake, that unit tested at near Silver efficiency as well. The other VP series models did not have similar testing results and should not be tiered similarly, but the 450 is a good unit.
http://www.hardwaresecrets.com/article/antec-vp450-power-supply-review/1487
