thechief73
Slickzor, you really have a good grip on the situation, and if you know that those voltages are fluctuating that badly then I would say follow your gut.
As for Memtest86+, I have seen countless overclockers, PC guru's, and general PC users all recommend to use Memtest to check and see if your memory is functioning properly. I would not understand its popularity and how widely it is recommended without it being a good working/reliable program. I have used it myself and I trust it.
For the PSU, if it is not a problem for you to get the 620w go ahead and do it. Your plan sounds like the best I could come up with and its what I would do in your situation. RMA the defective one and sell the PSU they send you back. Buy the 620w and you will be able to upgrade your GPU at a later time without worries.
As for RAM, if you end up needing to buy it, 4GB will get you by, 6GB is good for gaming and to makes sure your OS and other programs respond quickly. You do not need to go over 6GB unless you want to 3D render, Photoshop, or do alot of video editing.
Speeds of 1333MHz are just fine, but 1600MHz only costs a tiny bit more if not the same(at least in the US) so go for the 1600MHz, any faster you may run into issues where you'll need to mess with settings in the BIOS, and faster speeds than that are really not nessasary as they do may only give a few % increase in performance if any, and that will not be visible in the real world only in benchmarks.
For CAS timmings anywhere from CAS7-CAS9 are good and again the differnce between them are probably not noticable to humans only benchmark software, that said if you can find CAS7 RAM go for that before CAS8 or CAS9, the prices should be them same or very close to each other(they are here). One other thing I would offer as advice is look at the RAM voltages, 1.5v is good because that means the RAM can run at that speed with less power and stress on the memory, but its more rare than 1.65v RAM. 1.65v is the normal for DDR3 tripple channel and there is nothing wrong with using that either and is usally the standard, its just that that is the highest recommended voltage from Intel for RAM on i7's, so I just feel its better for your PC to go with 1.5v.
Brands that are Ok, check you QVL(Qualified Vendor List) for your motherboard first. Kingston, G-Skill, Corsair, Crucial, OCZ are all good brands to consider.
