[SOLVED] Which ram speed for i5 8400?
amir.bisk
24
Hi folks
Im going to buy i5 8400 with TUF h370 and 1060 O6gb
I haven't decided on ram yet.
some guys telling me that I had better buy 2x8gb Hyperx 3000mhz cl15. the speed will reduce to 2133.
Should I change it to 2666 or let it runs at 2133?
or is it better to buy 2x8 gb 2666 rams?
I just want to do some games , sometimes AfterEffect (not so heavy rendering)
Memory speed only affects certain games, and even in those titles it doesn't make a huge difference. Go with what you can afford, obviously faster is better overall, but your system won't die if you use 2133.
hyperx 3000mhz is cheaper. Should I change speed to 2666 with higher timing or to 2133 with lower timing?
