Question Which SATA data cable do I use for my optical drive?
Oct 25, 2024
14
I'm building a new PC and reusing my optical drive. It had a red SATA cable connected to it. My motherboard comes with SATA 6 GB/s cables and ports Should I use the data cable that comes with the motherboard instead of the other that was being used by the optical drive? Thanks
Use the cable that's long enough without stretching tight and has the correct connectors on both ends. Everything else is completely irrelevant.
