Question Which VGA cable should I be connecting?
ahmd3500
52
So I bought the bitfenix whisper 750M and it has four 8 pin connectors, 2 above each other as "VGA 1" and two above each other as "VGA 2"
Knowing that GPU is RTX 2070 Super, MSI Gaming X trio what exactly do I connect to it?
Two 8 pins from both the VGA 1, VGA 1?
or One 8 pin from VGA 1 and one 8 Pin from VGA 2?
Or does it not matter at all cuz am using a single gpu anyways and all will provide same wattage?
This is how the psu looks: https://gzhls.at/i/32/44/1543244-n2.jpg
Also what's the "Molex" for?
And what's the secondary motherboard below the motherboard 24 pin for?
Motherboard:B450 gaming pro carbon
Case:mb530p
Thanks in advance <3
It shouldn't matter which VGA is used. I'm not sure what the other motherboard connection is for, but the SATA/Molex connectors are for DVD drives, HDDs, SSDs etc. Molex is the old type of connection for these, made of a chunky, typically semi-clear white connector with 4 pins. SATA is the one used nowadays.
