Some quick questions:
1. The heatsink fan over the CPU: does this blow air into the CPU (into the mobo) or up away from the CPU?
2. Side panel fan (right above the CPU when the side panel is placed back on the case): Should this blow into the case (and into the CPU) or out of the case away from the CPU?
EDIT: While I'm at it, some more questions hehe:
3. To which side do the fans blow? Blow air through the side with the sticks?
For example: http://en.wikipedia.org/wiki/Image:IMG_1549.JPG
Would this blow up or down?
4. I have different strength fans (one came w/ case, two I bought). Do I want the stronger one in the front intake, or stronger in the back for exhaust? (Or side panel fan?)
(Came w/ case: Raidmax generic 80mm; Two I bought: Antec TriCool (Adjustable 3 speed) http://www.antec.com/us/productDetails.php?ProdID=75080 )
