So here is my set up
Case - Thermaltake Amror Revo Gene Black
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133210
Motherboard - ASUS Z87-A http://www.newegg.com/Product/Product.aspx?Item=N82E168...
CPU - i5-4670k http://www.newegg.com/Product/Product.aspx?Item=N82E168...
CPU cooler - H100i http://www.newegg.com/Product/Product.aspx?Item=N82E168...
RAM - Corsair Vengeance Pro 2x4gb 1866mhzhttp://www.newegg.com/Product/Product.aspx?Item=N82E168...
GPU - MSI Geforce GTX 770 2gb oc/tf http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Power Supply - Corsair RM850W http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Front 200mm fan - Intake
Side 200mm fan - Intake
Top H100i 120mm x2 fans - exhaust
rear 120mm fan - exhaust
my question is...which way should my RM850 PSU fan should be facing? As of right now I have it facing down, so the fan is facing down. I just want the best negative or positive fan pressure my case should be getting. I'm sorry if I sound like a noob, I kind of am when it comes to this stuff. Thanks for any suggestions you guys have. You're all the best at it!
