which wires of a male molex connector do i solder onto the positive and negative of an led strip?
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
which of the wires of a male molex connector do I use as positive and negative?
well I want to solder a male molex connector to an led strip so that I can connect the male molex to a female one that plugs into my power supply.
the input for the led strip is 12v
36 watts
.6A
I know nothing about that lol. could you tell me how to solder the male molex onto the led strip?
or do I only have to solder the yellow and black to the strip?
Just solder the yellow wire to the positive and the black wire to the negative. Of course, if the LED strip doesn't have a current limiting resistor it will just burn up either the LED strip or the PSU or both.Possibly catching on fire and burning you and/or dripping melted plastic into the case and destroying your mobo which catches on fire and scares you so badly you run out the third floor door onto your balcony where the rail breaks, over you go, and that's all there is to it - bye, bye.
Since you admittedly don't know what you are doing, lol, why don't you take it to a shop?
Current Limiting Resistor Calculator for Leds
ugh I give up
