[SOLVED] White sticker for motherboard heatsink
anonymous890
219
4
4,695
View: https://imgur.com/a/aVfOrUO
I have an ASUS ROG STRIX X570-F and I want to cover the heatsink with white sticker for a complete white build look (see attached picture)
Do you have any recommendations what kind of white sticker I can use? something that won't affect the thermals, won't cause any static or damage to the motherboard and something I can remove anytime and won't void the warranty.
Thank you very much for the help.
also if anyone could answer
I went and paid someone to paint my gpu to white, he used a gray primer and then white spray paint, it kinda looked a bit white but a bit caramel, not pure white, is there a way I can go pure white?
White vinyl wrap might work...like this. Apply and trim with a razor blade. I like the white...
White vinyl wrap might work...like this. Apply and trim with a razor blade. I like the white carbon fiber look. Any sticker will adversely affect the ability of the heatsink to shed heat to the air...hopefully not much though. Even paint does.
A second coat of paint for the GPU. Pick the white tone to match...and be sure to wipe it off with alcohol first to clean and help adhesion.
