I've recently built a pc and as I was checking for temps, I noticed that minimum temps are 0 degrees. I observed it and it just happens for a second then back to normal. I searched about it but haven't found the same case as I'm experiencing, but someone mentioned about a temp sensor thing. Maybe it's that? This is my first build so I don't know if this is normal. Any help would be greatly appreciated!
I've already tried reseating/repasting the cpu cooler but to no avail. My guess is that temp sensors are faulty, which i'm not familiar with. I'm just worried that this could be a problem in the future. If not, then I'm letting it be.
Here's my specs:
CPU: intel i5-11400f
Motherboard: gigabyte B560M AORUS PRO AX
Ram: 2x8gb gskill tridentz
SSD/HDD: 500gb ssd
GPU: gtx 750ti
PSU: seasonic 650w focus gold
OS: Win10 19043.1110
CPU cooler: ID cooling se 224 xt
BIOS version is F3
Here's my specs:
SSD/HDD: 500gb ssd
GPU: gtx 750ti
BIOS version is F3
