I've had a lot of problems with computers over the years, but I never imagined anything quite as hard as picking a correct PSU!
I ordered some parts for a new computer. I was hoping to make it a cheap and very energy efficient machine with a killer GPU. Here it is:
AMD Phenom II X4 945 Deneb 3.0GHz 95W Quad (socket AM3)
ASUS M4A78T-E AM3 AMD 790GX HDMI ATX AMD Motherboard
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666)
Sound Blaster X-Fi Xtreme (PCI sound card)
Run of the mill DVD-RW (SATA) and 750GB HD (also SATA)
and a VisionTek 900297 Radeon HD 5850 1GB 256-bit GDDR5 PCI Express 2.0 with one 80mm case fan and 4 USB devices (mouse,keyboard, scanner, and webcam)
So, idiot that was, I went to Thermaltake's PSU calculator to find out what I should get for a psu. I typed in everything above, and it said the max wattage draw should be around 314w
Well, excellent, I think to myself, I'll go to newegg and get something. I get a 380 Watt EarthWatts unit. I look on Wikipedia and see that the ATI 5850 uses as max of 151 Watts, with a 95 Watt CPU, that makes sense right? And I think to myself, there's over 70 watts of wiggle room, so I should be good!
Well, after I order the PSU I learn that you have to know about 'rails'. I look at the back of my PSU and it says this:
I read that the 12 V rail is the most important for graphics cards. If this is true, then PSU gives 17 Amps on one of the 12 rail, and that's 17 x 12= 204 Watts. That should more than cover the ATI 5850 which needs a max of 151 W right?
I need help! Can this PSU run my computer setup as is??? What do all those numbers on the back of my PSU mean???
Thanks!!
Thanks!!
