Hello all,
I would like to know from you all:
1. What is high density about all new RAM?
2. What is the technical reason it doesn't work with some motherboards?
Case in point:
My motherboard is an LGA775 P43 chipset ASUS P5P43TD board. I recently purchased Kingston HyperX 2 x 4GB DDR3-1600. The RAM doesn't work. After finding out about the high density, low density difference I wanted to know what is it on a hardware level/software level that inhibits the proper operation?
Thank you.
Case in point:
Thank you.
