[SOLVED] Why does my drive keep disconnecting and everything on it crashes, for example steam.
May 9, 2020
Every now and then about 37 times a day my E: Drive disconnects and its location in my files appears on my screen. Apps running on the drive like Steam and Battle.net crash and then the games i am running crash aswell. Does anybody have a solution for this?
I have the same problem and changing the cables did not work. However, you should try to change the cable first. As for me I have to assess a little bit further before deciding to buy a new HDD. What I meant by did not work is the HDD still disconnect and after reconnect itself windows explorer of related HDD will pop out, but ever since I changed a new cable it only happened in less frequency than previous cable used. The problem is, it still disconnecting.
