Why does my graphics card not have drivers when I open my pc?
ProPlayerGR
595
42
19,040
Hi guys. In the past two days I open my pc and for 5 minute period or so my gtx 1070 doesn't have the driver installed for some reason. After 5 minutes the drivers are ok and everything runs nice. I am just wondering why this happens. Can someone explain to me? Thanks in advance.
PC SPECS:
CPU: AMD FX 9370 4.4GHZ
GPU: NVIDIA ASUS GEFORCE GTX 1070 FOUNDERS EDITION
PSU: EVGA SUPERNOVA 850W G2
CPU COOLER: CORSAIR H100I V2
SSD: SANDISK ULTRA II 240GB
HDD: WD 2TB
CASE: CORSAIR OBSIDIAN 750D AIRFLOW EDITION
MOBO: ASROCK 990FX EXTREME9
RAM: CORSAIR VENGEANCE 16GB PRO 2x8GB DDR3
Interesting situation, and I've never heard of anything similar before.
How is your OS install? New(er)? Or long-term?
I would suspect a dependency from another driver - are all motherboard/chipset drivers up-to-date?
Could that you've disabled certain "startup" items that impact the drivers ability to run - GeForce Experience etc, maybe? Just speculating here.
Yeah geforce experience doesn't open with windows startup but it opens after 5 minutes. This has happened to me before but it was fixed for all this time. Should I reinstall the drivers and geforce experience? Also take in account that I accidentally hit my case with my chair 2 days ago and this caused my pc to crash. When I opened it afterwards this problem occured. Thanks again.
Well this problem was occuring then because I hadn't updated the drivers for 2 months and once I updated them everything was fixed. This time is another case from the other one. I'll check if the card somehow moved from the knock and I will update you. Thanks again man I appreciate your help.
Edit: Sorry for delayed reply but I was busy. Well the problem is still occuring, I opened my pc I checked the card and there was nothing wrong with it. Take also in account that my ssd is not appearing in corsair link as it used to appear there. Any ideas?
