Hi, I recently bought a dell xps 15z with i5 2430m 2.4 ghz processor. I know it has turbo which I think lets the cpu overclock itself all the way up to 3.0 ghz. I was looking up stuff about cpu temperature and what not and so I downloaded realtemp which showed me that the cpu is running at 2.7ghz. After doing some reading online I still don't have a clear answer so I decided to ask more knowledgeable people and here are my questions:
I assume the standard frequency for this cpu is 2.4 ghz but why is it always at 2.7 ghz when the only thing I am running is chrome?
Is the 2.7 ghz like a total from both cores running together or is it just like the cpu average or what? for instance if 1 core ran at 1 ghz and another at 700 mhz that's understandable.
when they say the cpu speed is 2.4 ghz they mean both cores can reach 2.4 ghz or is it that both cores can reach 1200 mhz for a total of 2.4 ghz. this website says the max speed is 2.7 with turbo both cores active but 3 ghz for 1 core active. So does that mean both cores running each can reach 2.7 ghz and when only 1 core is running it can go up to 3 ghz? so technically if both cores ran at 2.7 that's 5.4 ghz of work?
I did notice that when I messed around with the power settings such as balanced or power saver or maximum power. the frequencies changed. When I did power saver the cpu frequency stayed at 798 mhz, max power the cpu stayed at 2.7-3 ghz and balanced is what is recommended so that's what I always use but I don't know if I should be worried that the cpu is always running at 2.7 ghz which I assume is with turbo on.
Sorry I know I am asking a lot of questions, it's just being a college student, I had to work my entire winter break to save up for this laptop and I just want to take care of it because I probably wont be able to get another 1 for a while so excuse me. and I really appreciate any answer at all. thanks!
