I am running an i5 7600k on an MSI tomahawk z270 motherboard. When I first built my computer the CPU was running about 20 degrees Celcius with my h100i v2.
Last month I realized that I have been running idle at around 40-50 degrees. When I would run the stress test my CPU would be at 100 degrees and I would notice a lower score on the benchmarks.
My first thought was that maybe I needed to replace the thermal paste, but after doing so the temperatures never changed. Then I dusted out my computer and the radiator. After doing this the temperature did drop about 5 degrees idle. Now it is currently running at about 40-45 degrees at idle.
My first thought is that maybe the motherboard is running too much power to the CPU. I have my CPU overclocked to 4.5GHz at around 1.1v not sure if that is normal I am just using the motherboards default settings.
It is not the pump on the water cooler it is running properly and turned onto "Performance" mode using corsair link. I do not hear any air bubbles or odd noises from the pump.
