Does it work, play, make enough fps to be enjoyable? That's all that matters. It doesn't matter what anyone else gets.
Gotta figure that most ppl using benchmark test sites like UBM aren't just there posting numbers to see where they stand, those type ppl could generally care less. Mostly it's ppl who have tweaked systems for better performance. They'll have gone through windows and turned off/disabled many of what you'd consider normal use startup stuff, like Cortana, windows tiles, one drive, Adobe, they'll change cpu/bios settings like PBO (which do not show up in UBM) added higher grade cooling (which lowers temps, so adds boost), tweaked/undervolted (which doesn't show up in UBM, lowers temps, improves boost) etc etc.
You aren't in comparison with 2 cars straight off the dealership lot, you compare your new car stock car to one that's had exhaust work, computer tuning, and is running race gas and slick super wide tires. You are going to come in second place no matter what.
