It’s says Ryzen 3000 compatible does this mean I still need to update?Does the motherboard have the required BIOS version installed to support the 3rd generation Ryzen (2301 or higher)?
||ASUS USA
www.asus.com
Thank you this is a new build and has never worked. The fans don’t spin neither do I hear any beepsIs this a new build? Has it ever worked? That motherboard may need a BIOS update to support the 3600x.
Do any LEDs light on the motherboard? Is the PSU toggle switch in the ON position (back of PSU)?Thank you this is a new build and has never worked. The fans don’t spin neither do I hear any beeps
Maybe, you need the proper version installed BEFORE you can use the 3rd gen CPU.It’s says Ryzen 3000 compatible does this mean I still need to update?
Yes the psu is on the mobo lights up but there are no beeps or led indicatorsDo any LEDs light on the motherboard? Is the PSU toggle switch in the ON position (back of PSU)?
Do you have access to an earlier generation AM4 CPU to use to update (verify) the BIOS version?Yes the psu is on the mobo lights up but there are no beeps or led indicators
It’s says “AMD RYZEN 3000 DESKTOP READY”"Ryzen 3000 compatible" is not the same as "Ryzen 3000 Ready".
No I asked Newegg and some stores around me but none are willing to loan me an old cpu or update the bios for meDo you have access to an earlier generation AM4 CPU to use to update (verify) the BIOS version?
Thank you very Much I’ll check it outLook for a Micro Center near you. They can help with this for a small fee.
Thanks I’ll contact them do you know how long it takes?You can use the https://www.amd.com/en/support/kb/faq/pa-100#faq-Short-Term-Processor-Loan-Boot-Kit
AMD will send you one that you can use and you have to return it after that.
Sadly it seems my board is one of themI saw a few board like yours that needed a BIOS update even with the ready on the box. 🙁
You should be able to schedule an appointment with them to check this for you. Only takes a couple minutes.Thank you very Much I’ll check it out
