Question Why my laptop shows 1600mhz speed but my pc 800mhz?
Oct 11, 2019
6
I have a HP laptop and installed two ddr3 4gb 1600 ram. in task manager it shows the speed 1600mhz. I did the same with my pc but it shows the speed 800mhz! why?
my pc: mobo msi 970a-g43, cpu fx-6300, 2 ddr3 apacer 1600 4gb.
thank you in advance
Well... should i do something with my DIMM slots on my pc or configuration in bios? I've tested all slots on my pc but it didn't help! why my laptop shows the correct 1600mhz?
Nothing you can do, it's windows "thing". Double check with programs like CPU-Z, Aida, HWinfo etc and don't forget to multiply by two. There's no way DDR3 would work at 800MHz, that's top speed for DDR2.
windows will report what your bios tells it, theres nothing you can do about it if your bios shows reall clock or "fake" wannabe clock
btw ddr3 800mhz exists (pc3 6400)
so when task manager on my laptop says the speed is 1600mhz it is fake? and when task manager on my pc says the speed is 800mhz it is real? I installed the same windows on my pc and laptop. I bought 2 ddr3 4gb 1600 for my pc and 2 ddr3 4gb 1600 for my laptop. I can't understand why pc says speed: 800mhz but laptop says speed: 1600mhz!! It confused me!!
alright, just do this: download CPU-Z, open SPD tab, and look "max bandwidth" tell us what it is (PC3-12800 or 14200 or something). and what mhz under the ( ) is. it should tell you what kind of RAM you're running. also, damn I didn't know DDR3 800mhz do exist. never saw one in my entire life.
well I did what you said dear. it is written Max Bandwidth: PC-3 12800 (800 MHz) for both rams. Slot 2 and 4
