[SOLVED] Why my motherboard passed POST without GPU installed and no integrated graphics ?
Nov 12, 2023
9
So i take off my gpu and test my motherboard.
The post indicator thinks the system is normal even tho im not using gpu.
The ssd already has windows on it so its not weird to pass the test but why the gpu also have no warning?
The CPU doesn't even have integrated graphics.
Ryzen 7 5700x
Mobo asrock b550 pro 4
When you said Used GPU I assumed it was an old one of yours, not a second hand one.
That is why I ignored it. I assumed it had worked before (for you) and now it wasn't in a new PC.
far more likely to be GPU then. they just need to run it for long enough.
have you plugged monitor into GPU and not motherboard?
Was GPU working before you took it out?
what are full specs?
Nah.
Evga rtx 3060
Its working normal. But after i leave it on for 2 hours the screen goes black . All part are normal. I just doesn't have other gpu to test it
All new part. Except used gpu. Msi a650bn. After that 2 hour. My pc cant show anything. Even bios. But i hear the windows log in sound
always 2 hours? regardless of what you doing?
what PSU do you have? what are parts in PC?
cleaned fans recently? could be overheating.
does it happen in safe mode?
next question would be: does it happen if you just sit in bios for 2 hours.
Ryzen 7 5700x
Evga rtx 3060
newest bios on motherboard?
No safe mode because there no display at all
Seemed like this was a come and go sort of thing.
Something might have been done unintentionally whilst troubleshooting making things worse. We wouldn't know the full story in honesty.
Best you take it to a pc store for further servicing.
Yeah. I return that gpu to the seller. If it work at their store then something wrong with my motherboard 🗿
Reactions: loue
Yeah man thanks. If my screen still black after i bought new gpu then i will come here again😂🙏
