D Donal1552 Prominent Sep 17, 2020 10 0 510 Sep 17, 2020 #1 Tensor cores have proven to boost rendering operation like 3d application software by reducing rendering time. Specially in blender which used cuda as default feature but in rtx card using optix has proven to performance boost.
Solution M M mjbn1977 Sep 18, 2020 Yes, the significantly improved the tensor cores. Read this tech deep dive, then you know everything: https://www.tomshardware.com/features/nvidia-ampere-architecture-deep-dive
A animekenji Distinguished Dec 31, 2010 196 33 18,690 Sep 17, 2020 #2 The RT and Tensor cores have been redesigned. They are a lot more powerful than the ones in RTX 20 cards. Upvote 0 Downvote
D Donal1552 Prominent Sep 17, 2020 10 0 510 Sep 18, 2020 #3 animekenji said: The RT and Tensor cores have been redesigned. They are a lot more powerful than the ones in RTX 20 cards. Click to expand... Source any link ?? To back your answer? Upvote 0 Downvote
M mjbn1977 Distinguished Aug 20, 2015 940 116 19,490 Sep 18, 2020 Solution #4 Yes, the significantly improved the tensor cores. Read this tech deep dive, then you know everything: https://www.tomshardware.com/features/nvidia-ampere-architecture-deep-dive Upvote 0 Downvote Solution
M mjbn1977 Distinguished Aug 20, 2015 940 116 19,490 Sep 18, 2020 #5 and this is from the RTX 3080 review: Tensor TFLOPS FP16 (Sparsity)119 (238)( RTX 3080 FE)89 (RTX 2080 Ti FE)85 (RTX 2080 FE) Upvote 0 Downvote
