Why will my xbox not pick up my wifi
G
Guest
Guest
Hello,
i previoussly had my xbox connected to my wifi but i put a password on the connection now the xbox cant even find the network but my computer can ,whats up ,thanks callum?
Did you go in and adjust all the network settings on the Xbox? If you now have a security key for the woreless the Xbox needs to have that in order to connect.
I would look at the router and write everything down again and then change the Xbox settings to match
(SSID name, type of security (WEP, WPA or whatever), TKIP or AES, security key, and passphase if one was used.)
