i had a gtx 1650 an intel i5 9400f 16gb of ram my motherboard was asus prime h310m-r r2.0SPECS?
yeah i just realised my front panel cables wasn’t plugged in correctly i’m going to get the motherboard manual up and see if i can plug them in and see if it turns on i’ll let you know 😅Triple check all the cables, make sure everything is plugged in
okay i plugged them in and my pc id turning on but my fans don’t spinTriple check all the cables, make sure everything is plugged in
The case fans or the CPU fans?okay i plugged them in and my pc id turning on but my fans don’t spin
i just realised i’ve got rgb fans and my old psu has the cyber power thing connected to it for the rgb fans is there any was possible i could get it to connect to my new psu?The case fans or the CPU fans?
are your PC fans connected with this? Follow the sata cables and make sure they are attached, older fans use these sata to molex cables a lot and sometimes its hard to track where they are plugged intoi just realised i’ve got rgb fans and my old psu has the cyber power thing connected to it for the rgb fans is there any was possible i could get it to connect to my new psu?
yes the one on the right is the one my fans use but my old psu has a cyberpower led fan where i need to plug my fans in to turn on and it’s actually connected into the psu itself so i’m not sure i’m going to get these fans to turn on because i don’t know if it’s possible to get that outare your PC fans connected with this? Follow the sata cables and make sure they are attached, older fans use these sata to molex cables a lot and sometimes its hard to track where they are plugged into
I see what you mean. You need to order one of these adapters so you can plug in your fansyes the one on the right is the one my fans use but my old psu has a cyberpower led fan where i need to plug my fans in to turn on and it’s actually connected into the psu itself so i’m not sure i’m going to get these fans to turn on because i don’t know if it’s possible to get that out
thank you, also i bought this pc no longer than two days ago and i’ve turned it on and it’s making a cackling noise is that normal?I see what you mean. You need to order one of these adapters so you can plug in your fans
Amazon.com: COMeap 6 Pin Male to 3X 15 Pin SATA Female Hard Drive Power Adapter Cable for Seasonic Antec Modular Power Supply 20-in(50cm) : Electronics
That, or get fans that connect directly to the Motherboard
Amazon.com: Noctua NF-P12 redux-1700 PWM, High Performance Cooling Fan, 4-Pin, 1700 RPM (120mm, Grey) : Electronics
What PC part does the noise come from?thank you, also i bought this pc no longer than two days ago and i’ve turned it on and it’s making a cackling noise is that normal?
Unless the sound is too much (means its knocking against the PSU frame, and long time could do damage) you dont have to worry. If its too much get it checkeddo i need to worry?
it’s okay it’s just a little cackling noiseUnless the sound is too much (means its knocking against the PSU frame, and long time could do damage) you dont have to worry. If its too much get it checked
