[SOLVED] Wierd ASPM error with Z390 chipset and Gigabyte aorus Z390 Pro motherboard ?
Euroman28
213
9
4,595
I have been running a system based upon for Z390 Pro from Gigabyte for a year, and there is something which I have been able to solve, its regarding ASPM and Windows 10.
When I via Powershell run powercfg - energy.
I get the following energy-report.html.
View: https://imgur.com/a/oW0IVq7
error 1 comes from.
USB\VID_046D&PID_C52B
https://devicehunt.com/view/type/usb/vendor/046D/device/C52B
which is the Logitech Wireless dongle for old Wireless Mouse.
error 2 comes from.
USB\VID_048D&PID_8297
which is https://www.devicekb.com/en/hardware/usb-vendors/vid_048d-pid_8297
Which is an RGB controller which I don't even use.
Error 3 is my Logitech Webcam.
Thats not the interesting part, all three error are all tied to the PCI\VEN_8086&DEV_ 36D which refers to https://www.driveridentifier.com/scan/download.php/download/1227672356/4641262C3A5E44FDA571CAB8BE0F7702/PCI\VEN_8086&DEV_8C31&REV_00
Which refers to Intel USB extensible 3.1 host controller.
If I try reinstall this controller driver, then all internal USB 2.0 connectors including the one connected to my ASUS wifi/bluetooth card disconnect.
Why a USB 3.1 controller would have handle operations on a USB 2.0 that I don't understand?
Machine runs Window 10 (latest build), have all latest drivers from Gigabyte installed, including the latest bios. And what the wird thing is if I enabled ASPM in the bios then wifi will not work. But I disable ASPM wifi comes back.
Have I have messed up something? Or is some unsolved error with that almost 3 year old motherboard and Windows 10? And how it handles USB power admin?
all USB actions in PC are controlled by the USB 3.1 extensible host controller.
if you click on a USB item in Device manager, and then swap View to by Connection, it shows all USB are under USB 3. 1
Do you have latest version of Intel Management Engine Interface as it might fix the USB problems.
PCI Express Active State Power Management (ASPM)
Active-state power management (ASPM) is a power management mechanism for PCI Express devices to garner power savings while otherwise in a fully active state. Predominantly, this is achieved through active-state link power management; i.e., the PCI...
Active-state power management (ASPM) is a power management mechanism for PCI Express devices to garner power savings while otherwise in a fully active state. Predominantly, this is achieved through active-state link power management; i.e., the PCI Express serial link is powered down when there is no traffic across it. It is normally used on laptops and other mobile Internet devices to extend battery life.
https://en.wikipedia.org/wiki/Active_State_Power_Management
what is the default?
