Thanks for reading... Hopefully, someone can help answer these questions for me...
Okay these questions may sound a little strange but I really would like to know the answer, I have searched for hours and hours over the course of days and I can not find any information in regards to my questions.
Let me start by telling you I have 2 Identical USB 3.0 Wifi Adapters AC1200 They use the Realtek 8812BU Chipset (Chipset Info at Bottom Included in case)
Question 1) Is it better to have 2x Dual-Band Antennas (2/4&5Ghz) or
would it better to have 1 antenna dedicated 2.4Ghz and the other a dedicated 5Ghz Antenna?
Image of the Unit with 2 Antennas
So Imagine
One is an AC1200 USB 3.0 Wifi Adapter and it uses 1x 2.4GHz antenna and 1x 5GHz Antenna
The second is an AC1200 USB 3.0 Wifi Adapter BUT it uses 2x Dual-Band Antennas (2.4&5Ghz)
WHAT IS BETTER ???
Is 2x Dual Antennas The Same as 1x 2.4 and 1x 5Ghz?
PLEASE LET ME KNOW.....
2ND QUESTION WIth Wifi Antennas Do You Need a MIMO Antenna? I included the Realtek Chip Info and it says it supports MIMO.
How do you take advantage of MIMO does it Matter what Type of Antenna? Does it have to say MIMO on it when being Sold? How is a MIMO antenna different from a 2.4Ghz or 5GHz or how is it different from a Dual-Band Antenna???
Very Confusing Info on the Antenna part with MIMO and what is needed?
THANK YOU!!!!!
Detailed Info on the Realtek 8812BU Chipset
802.11AC/ABGN USB WLAN NETWORK CONTROLLER
General Description -
The Realtek RTL8812BU-CG is a highly integrated single-chip that supports 2-stream 802.11ac solutions with multi-user MIMO (Multiple-Input, Multiple-Output) and Wireless LAN (WLAN) USB interface controller. It combines a WLAN MAC, a 2T2R capable WLAN baseband, and RF in a single chip. The RTL8812BU-CG provides an outstanding solution for a high-performance integrated wireless device.
Features -
General:
TFBGA 6.5x6.5mm package
802.11 ac/abgn
802.11ac 2x2, Wave-2 compatible with MU-MIMO
Host interface
USB3.0 for WLAN controller
So Imagine
WHAT IS BETTER ???
THANK YOU!!!!!
Features -
General:
802.11 ac/abgn
Host interface
