[SOLVED] WIFI Booster for wired connection
Dec 28, 2021
4
Hi, was hoping for some advice. I have recently upgraded from fibre to ultrafast fibre. Before the upgrade I had a PS3, PS4 and NOW TV box connected by ethernet directly to the router. However due to where the ultrafast comes in to the house a wired connection is not practical and I have connected these devices via wifi. The router is around 10 feet from these devices, with a direct line of sight. I am only getting speed of 16 mbps on the PS3 and 40 mbps on the NOW box and the PS4. Other devices around the house are getting around 100 mbps so I assume that the problem is with the wifi tech in these older devices.
To get round this I was thinking of using a wifi booster (Netgear N300) connected to an ethernet splitter (TP-Link TL-SG1005D) and then the three devices connected to the splitter.
Any opinions on whether or not this would significantly improve speeds and if so are the booster and splitter I have mentioned good choices. Thanks
I guess I forgot how old things like ps3 and pc4 actually are. The speeds you get are OK for the wifi technology they use. I don't know about the now box.
I would tend to favor a more modern solution like the one recommended by colgeek rather than the netgear n300. To a point it depends on what you main router uses. Part of your issue with the ps3 and ps4 is your are restricted to using the 2.4g band. Even with a much fancier router than even the n300 you will not get 100mbps.
You might get maybe 60-70mbps with the n300. To get faster speeds you need a device that can run on the 5g radio band. In addition 802.11ac is going to be much faster than the older 802.11n. It is not uncommon to get 150-200mbps on a 802.11ac...
Hi, because of the layout of the room the router is 10 feet diagonally across the living room floor. Obviously dont want to run a cable across the floor and running around the wall would require multiple bends around doors etc. This is why I thought a wireless connection to the booster and a wired connection to the devices would bypass inadequate wifi cards
You might get maybe 60-70mbps with the n300. To get faster speeds you need a device that can run on the 5g radio band. In addition 802.11ac is going to be much faster than the older 802.11n. It is not uncommon to get 150-200mbps on a 802.11ac with a 1200 number on it.
Now none of this matters if your main router is older also. Your main router would need a similar 1200 number or larger to take advantage of this.
For the information of those who took the time to reply and anyone reading who may be in a similar position.
I decided to give my idea a try and ordered TP-Link RE505X AX1500 extender. The PS3 download speed has gone from 16 to 28 mbps and rhe NOW box from 40 to 78 mbps. Haven’t used a splitter/switch yet but I am happy with the improvement.
