Hi
I plan to buy an used Asus H81I Plus motherboard to mount a slim desktop. I intend to use the wireless internet, essentially to surf and watch movies. As this motherboard does not have built-in wifi and has no Pcie slot to put a wifi card, I thought to use a standard wifi pen drive or a pen drive with an antenna. The desktop will be sometimes about 4/5 meters from the router (which has no antenna) and with two or three walls by the middle of the signal.
So, can I easily use the web using one of these pen drives, or is it better to buy a motherboard with integrated wifi? Or should I buy a mini atx and use a wifi card in the pcie slot? The motherboard I want to buy is a good deal. What is your opinion?
Thanks
Thanks
