As a result of a little virus some time ago I don't connect automatically in my wifi
Each time I reiniated the system I have to introduce the password again.
did you check your router settings and also if the connection is on auto after password been on you may need to press apply to have it on all the time .
what do you mean ?
I have not problem from other pc. So is this very one affected.
apply where exactly ? The connection don't give that option. Only mark automatically connection.
since you had that virus did you scan the system and i would redo network connection on this pc since it is the only one that does it also check in your router if the wireless mac address of this pc still in permit list .
