This is the reason why Microsoft encourages people to have their builds hardwired to the internet during Windows installation: they know that they can't include every driver that may be needed in the windows install package. This is especially true of brand new equipment and it doesn't help that Windows 11 is also brand new. And with more builds not having optical drives to read the...So it turns out it was just a simple driver issue. I had to install the wifi driver for the motherboard on a separate pc on a thumb drive. I was making the problem more difficult than it had to be, since my previous motherboard didn’t require wifi drivers for it to function I figured windows 11 paired with the new motherboard was causing issues.
So it turns out it was just a simple driver issue. I had to install the wifi driver for the motherboard on a separate pc on a thumb drive. I was making the problem more difficult than it had to be, since my previous motherboard didn’t require wifi drivers for it to function I figured windows 11 paired with the new motherboard was causing issues.Do you mean that wifi is turned on in the bios and it doesn't show up in the device manager? Given the newness of the components, Windows 11 probably needs an additional driver or more. Does the mobo support disk included wifi drivers or are they listed on the website?
This is the reason why Microsoft encourages people to have their builds hardwired to the internet during Windows installation: they know that they can't include every driver that may be needed in the windows install package. This is especially true of brand new equipment and it doesn't help that Windows 11 is also brand new. And with more builds not having optical drives to read the support CD provided by the motherboard manufacturer, its just going to get worse.So it turns out it was just a simple driver issue. I had to install the wifi driver for the motherboard on a separate pc on a thumb drive. I was making the problem more difficult than it had to be, since my previous motherboard didn’t require wifi drivers for it to function I figured windows 11 paired with the new motherboard was causing issues.
