Wifi extender with antenna
Khazen
5
So im going to our yacht next week its located in turkey at the moment and the. Marinas wifi is weak so i just wanted to be sure that the products i purchase will work with what im planing to do
So im thinking this wifi antenna
http://www.tp-link.com/en/products/details/cat-5067_TL-ANT2415D.html
http://www.tp-link.in/products/details/cat-10_TL-WA830RE.html
i will connect the antenna to the outside of the yacht and run a cable to the wifi extender
The wifi antenna will "grab" the marinas wifi and use the extender to make my little own wifi with a passcode
Will this work
I will have to disconnect one of the antennas on the extender and plug mine and use that for the marina and the small one for the yacht
I had also set up a working raspberry pie running kodi with live TV using internet but the signal is weak
Would love an answer ASAP!
so i watched a couple of videos on youtube and they're using something called the grove or Bullet that connects to the antenna and an Ethernet cable to it DO i NEED it for this setup to work or will the cable from the extender to the antenna will work?
i have purchased the extender and the antenna and 2 5M Male to female antenna cables
