indows IP Configuration
Host Name . . . . . . . . . . . . : RyanFactory
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : attlocal.net
Ethernet adapter Radmin VPN:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Famatech Radmin VPN Ethernet Adapter
Physical Address. . . . . . . . . : 02-50-74-C8-1E-3C
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
IPv4 Address. . . . . . . . . . . : 26.36.6.65(Preferred)
Subnet Mask . . . . . . . . . . . : 255.0.0.0
Default Gateway . . . . . . . . . : 26.0.0.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Realtek PCIe GbE Family Controller
Physical Address. . . . . . . . . : F0-2F-74-B0-8E-2A
DHCP Enabled. . . . . . . . . . . : Yes
Wireless LAN adapter Local Area Connection* 1:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 22-4E-F6-F0-C6-1F
Wireless LAN adapter Local Area Connection* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : A2-4E-F6-F0-C6-1F
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . : attlocal.net
Description . . . . . . . . . . . : Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC
Physical Address. . . . . . . . . : 20-4E-F6-F0-C6-1F
IPv4 Address. . . . . . . . . . . : 192.168.1.186(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, December 12, 2023 1:47:35 PM
Lease Expires . . . . . . . . . . : Wednesday, December 13, 2023 1:47:35 PM
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DNS Servers . . . . . . . . . . . : 1.1.1.1
1.0.0.1
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
IPv6 Address. . . . . . . . . . . : 2001:0:2877:7aa:c4c:18a6:9c8b:bc2(Preferred)
Link-local IPv6 Address . . . . . : fe80::c4c:18a6:9c8b:bc2%13(Preferred)
Default Gateway . . . . . . . . . : ::
DHCPv6 IAID . . . . . . . . . . . : 201326592
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-2C-35-36-66-F0-2F-74-B0-8E-2A
NetBIOS over Tcpip. . . . . . . . : Disabled
Even though you are not using Ethernet, doublecheck that the Ethenet card is not enabled.
Another thing that can be done is to use wireless antenna extension cables to further raise up and reorient the antenna toward the router.
Run "ipconfig /all" (without quotes) via the Command Prompt. Copy and paste the results herein.
May reveal some other problem or issue.
