Question WiFi Problems
MrPopo1212
5
All of sudden my desktop has begun having problems with WiFi connection.
If I can manage to connect to the WiFi I have no luck actually using it; I can't load webpages or generally connect to the internet in any way at all.
I can, however, connect with my phone and then use my phone's hotspot without any troubles at all.
I have swapped my network card with another from an older desktop but only had the same problems. Drivers are all updated.
Any help would be great.
Thanks.
I would:
  1. remove the WiFi network on the desktop and do a new scan for available networks
  2. If the WiFi network appears, connect with the correct password
If this doesn't help, I would create a new WiFi network on the access point with basic settings, just for testing even without access control. See if this works. Basic settings often include support for older clients explicitly, 802.11b for example.
If you have a dual band hotspot 2,4 and 5 GHz, you might check if there is no hardware issue with the wireless sender: The phone might be able to connect via 5GHz, while older WiFi cards in desktops don't.
hope this helps
Host Name . . . . . . . . . . . . : DESKTOP-DFBHD7N
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : Home
Ethernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) Ethernet Connection (2) I219-V
Physical Address. . . . . . . . . : 40-8D-5C-BD-3E-3F
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #3
Physical Address. . . . . . . . . : 16-66-B3-E3-9D-17
Wireless LAN adapter Local Area Connection* 12:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #4
Physical Address. . . . . . . . . : 26-66-B3-E3-9D-17
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . : Home
Description . . . . . . . . . . . : Qualcomm Atheros AR9287 Wireless Network Adapter
Physical Address. . . . . . . . . : 64-66-B3-E3-9D-17
Link-local IPv6 Address . . . . . : fe80::c9ca:c41:14d1:1831%6(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.6(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Sunday, 23 June 2019 6:28:21 PM
Lease Expires . . . . . . . . . . : Monday, 24 June 2019 6:28:21 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 107243187
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-24-A1-CA-65-40-8D-5C-BD-3E-3F
DNS Servers . . . . . . . . . . . : 192.168.1.1
192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
