irmakgun Dec 25, 2020 1 0 10 Dec 25, 2020 #1 Hello guys. I reset the wifi repeater. I think something happened and it is bugged. Power and WPS led constantly blinking and repeater is not seen in network. Can anyone help with this?
Solution velocityg4 Dec 25, 2020 If you reset it. You'll need to connect to it directly and reconfigure it. Using whatever utility or procedure the manufacturer recommends.
velocityg4 Glorious Nov 21, 2006 5,390 472 46,440 Dec 25, 2020 Solution #2 If you reset it. You'll need to connect to it directly and reconfigure it. Using whatever utility or procedure the manufacturer recommends. Upvote 0 Downvote Solution
