Wihich way to use Half D1- there are conflicting opinions ..
G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
Strait to the point... Do you use half D1 to fit more on a DVD, or to use
same bitrate and get better quality?
In my experience, encoding to half D1 doesn't reduce the file size to half,
so if you use half the bitrate to encode, you will lose quality in the mpeg
file. I haven't got numbers, but encoding to half D1 only reduces the file
size by about 25%. (which makes sense because you're only cutting one of
the two dimensions in half - the vertical) So, you're only getting a bit
more time on a DVD.. For VHS, isn't it better to keep the same bitrate and
take advantage of less info per frame, thus better quality encoding at that
bitrate? For example; VHS to a DVD at 4000kbps gives 2 hours at
not-so-good quality, vs., VHS to DVD at 4000kpbs at half D1, which needs
less compression to fit on a 2 hour DVD because it's smaller. Less
compression means better quality (for VHS).
I have read that using half D1 at a high bitrate is useless. I have done
tests and found that a video encoded at half D1 - 6000kbps has less mpeg
artifacts than a full D1 file at the same bitrate, and it looks better,
(Again, with VHS source)
So, how do we use half D1? ... To save space, or to get better quality
encoding for VHS archiving?
Sanman
In article <Lt6dnYruLvg3SBndRVn_iw@look.ca>, me@you.com
says...
Yes.
> file.
Only if you haven't tweaked your encoding parameters.
(Motion Search Precision is the key one that needs to be
considered, and probably a few others.)
Uhhhhh... the *only* factors that affect the size of a
DVD clip are the bitrate and the run length. Resolution
(full-D1 or half-D1) has *zero* impact on file size.
.... and I'd suggest you go back and re-visit Geometry
101 (704x480 is 337920 pixels, 352x480 is 168960 pixels
or *half* as many pixels)
Half-D1 probably stops showing improvement after 4000-
6000. However, where you draw the line depends on the
quality of the encoder, VBR vs CBR, Motion Search
Precision, and any other tweaks that have been made in
the encoder settings.
The fact that you noticed that half-D1 encodes better at
a given bitrate then full-D1 is a bit silly. It's half
the pixels, so naturally it will require a lower bitrate
then the full-D1 to achieve the same quality.
> Sanman
"Toshi1873" <toshi1873@nowhere.com> wrote in message
news:MPG.1aeef5552897e54b989872@news-50.giganews.com...
> says...
use
> Yes.
I agree, yes to both parts of your question.
half,
mpeg
> > file.
Very important points, and they can be, and most often
are, impacted if not controlled by your capture HW&/ SW.
(While this seems self evident, these factors are seldom
included in the selection/consideration of hardware or
software for this purpose.)
of
Basically true, but using the lower resolution can allow a
lower bitrate, and still handle image changes better than
would be the case at a higher resolution. As long as the
source image (analog) can be digitized without significant
loss, at a any particular resolution (digital); a "true to
source" result is possible. Increasing the resolution above
what is needed for reproduction of the source, shows little
if any improvement, in terms of the resulting image detail
or other factors associated with the benefits of higher (digital)
resolution. There is only so much image data in an analog
TV or VCR signal.
Ok;
Now what is here, is what was made of the original analog image
by the A/D chip (as a baseband, probably close to 100Mbps)
and then, for hardware sent to the MPEG Encoder chip or for
software provided in some "uncompressed" DV format.
If NO compression was applied then :
337,920 x 8bits = 2,703,360bits + 6,400bits (audio @192kbs)
= 2,709,760 bits per frame x 30fps = 81,292,800bps
168,960 x 8 bits = 1,351,680bits + 6,400bits
= 1,358,080 bits per frame x 30fps = 40,742,400bps
Every pixel rendered at 8 bits. ( of course there are 10 bit and
greater A/D encoder chips.)
Of course you never see the above, as MPEGs whole point
is to provide a compression to the images.
and
that
done
All true, but I don't see why it's silly? It's kinda the point
isn't it?
> > Sanman
Both, it's part of a balancing act that includes the points
that "Toshi1873" mentioned.
Luck;
Ken
> says...
use
> Yes.
half,
mpeg
> > file.
of
Yes, I'm aware of that. My mistake, I was thinking of capturing
uncompressed video at lower resolutions, not compressing.
Good point. Lose the sarcasm.
and
that
done
I disagree. Encoding half the data with the same bitrate will render less
artifacts in the encoding than with full D1. It makes perfect sense that
the encoder will have less information to compress at the same bitrate, and
will have to compress *less* to stay within that bitrate.
>It's half
Exactly, which is why it would look better at the same bitrate, other than
it being lower resolution. My tests show that there is far less motion
artifacting with Half D1 at the same bitrate as Full D1. The difference was
clear, especially during <pause>.
Thank you. You've answered my question.
Sanman
Both. For instance, I'm encoding material from VHS as half-D1 in 100%
CQ mode. This usually amounts to a bitrate between 6500 and 7000,
although at times it can even go beyond 7000. I get the best in
compression terms, and some benefit in storage ones.
Obviously. But the half-D1 / full D1 question is a complex one. If one
needs encode at very low bitrates, say 2500, because of storage
considerations, one would use half-D1 in all cases, because that
bitrate is very low for a full D1. But at higher bitrates, and for the
same given bitrate, half-D1 gives you better encoding quality while D1
gives you a sharper image. And there are factors that can very much
affect the result. For instance, low motion would favour the use of D1
(for a better detail), while fast motion favours half-D1 (reducing
artifacts). The use of filters (denoise, sharpening...) would also
favour one or the other. Commercial movies use D1, thus evaluating
better the resolution factor than the compression one. But that is
because they use of 8000 and above. At lower bitrates things may be
not so clear. I do not have enough experience to aseverate on this,
and would gladly hear from those that have it, but wonder if a 3000
kbps half-D1 may not look better than a 4000 kbps D1, in spite of the
lower bitrate -at least, in some cases.
I still think that in most cases, the Half D1 at 3000 will look better
than Full D1 at 4000. But it may depend on your source material.
High motion scenes are better represented with Half D1, and low motion
with Full D1. And if your source material isn't high resolution and
very sharp to start with, I see no reason to go Full D1 for your output.
See some examples for yourself:
http://dormcam.mine.nu:8080/restest
-WD
On Wed, 21 Apr 2004 14:45:20 GMT, Will Dormann
Nice and instructive photos. Pity the DVD standard does not allow a
per-scene resolution!
One more consideration: if you multiply 1150 (the Vcd bitrate) by 4,
you get 4600, which would be the bits/pixel equivalent of a 704x80
mpeg-2 for Dvd. For 720x480, it becomes 4705 kbps. Thus, 4000 kbps is
a really low bitrate for D1.
Now, I'm still wondering if Rempeg2 can do a better job than
DvdShrink, as it would use a resolution more appropriate to the
lowered bitrate; the con is that it re-encodes, which is a factor of
degradation. As Rempeg2 doesn't work for me, I may have to do the test
myself by a different and longer route.
