[SOLVED] wii2vga adapter and then hdmi to vga converter?
DynamicProgram
8
alright, so i've been looking to play wii on my lcd monitor for a long time, the thing is, it only has vga input. So i did some research on some local markets and found out, the only way i "could get it to work" is by buying a wii2hdmi adapter (this adapter im 100% sure it will work) and then convert that hdmi output to vga (not sure about this part), i was wondering if it would work?
What I would do is replace that old monitor with VGA only with one that has HDMI input since the cost of a used monitor is not much more than the cost of an HDMI to VGA adapter, and you have a newer better monitor along with that. If you just want to stick with an adapter you can try something like this, and make sure you connect the USB power to it https://www.amazon.com/Cable-Matters-Adapter-Converter-Black/dp/B00879DM56
this is the exact adapter im getting :)
