P Pidz0 Prominent Aug 20, 2020 7 0 510 Aug 28, 2021 #1 I want to ask you will 1660 fit in Biostar A320MD PRO, and will there be any other problems?
Solution RealBeast Aug 28, 2021 YES, it will work. Just check and see that you have a bios that is the required version or later from the linked page. You can also get drivers there.
RealBeast Titan Moderator Sep 13, 2010 17,109 474 104,790 Aug 28, 2021 Solution #2 YES, it will work. Just check and see that you have a bios that is the required version or later from the linked page. You can also get drivers there. Upvote 0 Downvote Solution
