will 2400mhz ram work with z77x-ud3h
Ayman IBreak
88
i have a
core i7 3770
gigabyte z77x-ud3h
6gb ram 🙁 1333 mhz
Gtx 680 gigabyte
600 watts PSU
and i don't like the PC performance
i guess the best thing to upgrade is the ram and i've found this on ebay
http://www.ebay.com/itm/161769895459
should i get it
the price here is double in israel
my mobo says 1333/1600/1866/2666(OC) i guess
so should i get them or should i get 1866 mhz
It wouldn't be a waste of money, because 1866 Mhz & 2400 Mhz makes absolutely no performance difference & prices of those 2 are identical too.
It will work fine ^^
Havent looked into the pricetags, but i guessed the 2400 would cost more, simply because its faster.
Sakkura, the MoBo says "support for DDR3 2800(OC)/1600/1333/1066 MHz memory modules"
What have i missed?
It supports memory speeds up to 2800, including 2400. It's just indicating that anything above 1600 is technically considered overclocking, because the Intel memory controller is officially rated for no more than 1600 (in practice it can handle a lot more).
Alright, learn something everyday.
