[SOLVED] will 3200MHZ run on my pc ?
Jan 13, 2021
9
hello and good day to you folks !
as the title implies i'm thinking of upgrading my ram into patriot viper 2x8(16gb) 3200MHZ and i was wondering if my system's current state supports it.
CPU : intel i5-6400
Mobo : Asus prime z270p
The motherboard supports up to 3866mhz,so ur good on that,but the cpu is only quaranteed to work with speeds up to 2133mhz,so whether ur gonna be able to run 3200mhz depends mainly on luck
