Will a 120GB SSD hold my C drive contents?
mja2106
12
Hi,
I was thinking about upgrading my windows drive to an SSD, so I cleared out as much as possible from my C drive and ended up with 113GB used on my C drive (Currently a HDD) and 351GB of free space.
However, I am unsure as to whether this will fit onto a 120GB SSD (Specifically a Samsung 840 EVO 120GB) as I know that the amount that windows shows the drive as is smaller than the size that the manufacturer gives, for example my 500GB Hard drive shows as 465GB. Therefore I would like to know:
Is this the same for SSDs (I'd think this is probably the case)?
Would the 113GB fit anyway?
If not, would it fit on a 128GB SSD?
Also, any opinions on the samsung 840 evo and samsung 840 pro are appreciated.
Thanks,
mja2106
No, most likely not. 120GB SSDs are usually ~111GB in Windows, and 128GB drives are ~118GB. For performance, it's usually best to have about 20% of free space on the drive, so you should probably look into a 250-256GB SSD.
A 120GB drive will show as 111GB in Windows due to the file system.
I am running Windows from a 120GB Kingston Hyperx 3K. And have 55GB free at the moment. For me 120GB is plenty for the operating system and software. I install all my games, and store file on a HDD.
EDIT: The Samsung 840 is one of/the best SDD's around. Obviously the Pro out performs the EVO but at a price.
My configuration exactly. And almost exactly the same used space.
Two of the best out there. You would not be disappointed with either.
