will a 120hz monitor work for me?
etchersoy23
91
I play CSGO a lot and I want to get really good at it, which I am improving, but I want to step up my display from a 32" Flat screen TV to a 120hz monitor. I run about a constant 117, 118, 119, and 120 FPS most of the time. Does this mean I can get the 120hz monitor? I wanted a 144hz to begin with but I'm not sure about all this. I also used to get over 200 frames on CSGO but then I got an autoexec file and after that I ran the 120. But I changed my graphics settings to all the way to low and still play with 120fps. There's absolute no difference if I play with my graphics settings high or low. Still getting that 120.
From a technical standpoint. Buying a 120 Hz display won't make you any better. However, it will likely have a lower input delay than your TV set. The higher refresh rate will allow for smoother movements, if someone is peeking around a corner quickly, it won't be a blur, it will be sharp and it will allow you to aim more accurately. This is because on a 60 Hz panel, no matter what the response time is- you will see some degree of ghosting during fast motion. It's different from our eyes because we react to movement, we're no a display that's updating every X ms. However, with that said. It's mostly placebo but it might be easier to improve, though there are gamers that play at 40 FPS on a old 60 Hz panel and still manage to climb the ladder to the top, so definitely preference rather than easier to learn if you will. Buying a 144 Hz monitor might be a better option because there are more to choose from, as this is currently the competetive gaming norm. If you could tell us your budget, I'll be more than happy to help you find your new monitor! :)
I know that getting a 120hz Monitor will not improve my gameplay or skill, but I just want one. So running at a 120fps I will be able to have a 120hz or a 144hz monitor? My budget ranges from $100 to $200. I hope the monitor is what it is worth.
