Will a AMD FX8350 work with a ASrock 990fx extreme3 out of the box.
i dont know if anyone has looked but it is still on their supported list i have just brought one and i am looking at getting an 8350 for it as an upgrade from the 955 phennom ii
thats a shame. do you know anything about the thermal issues they have been having as atm im the king of keeping things cool with extreme messures as i hve thermal issues with my current system as im running sli i can tell you that my case sounds like it will take off
I installed this combination( without reading this site) and the CPU fan whistled like there was no tomorrow.....temps got up to 68"C at some stages and when I went through the settings HT ratio was at 19 !!! as default !! I dropped it down to 11 and it runs very nicely now.
I have just bought this Motherboard as an upgrade to my old ASRock M3A790GMH.128M but for the time being I am not buying a CPU and will install my existing AMD Phenom II X4 965 BE,
I upgraded purely for the SATA3 and USB3, also will upgrade to a newer FX CPU in the future.
If you read in the compatibility site of ASRock it does mention that * For cooling the CPU and its surrounding components, please install a CPU cooler with a top-down blowing design.
