will a amd wraith cooler fit ?
jhern123
Commendable
Feb 1, 2017
looking to upgrade my fx 6300 with a diffrent
amd with wraith cooler but is it possible for the cooler to fit ?
MOBO Gigabyte Technology Co. Ltd. GA-78LMT-S2 (Socket M2)
http://www.gigabyte.com/products/product-page.aspx?pid=4208#ov
system specs |
Operating System
Windows 10 Pro 64-bit
CPU
AMD FX-6300 27 °C
Vishera 32nm Technology
RAM
8.00GB Single-Channel DDR3 @ 669MHz (9-9-9-24)
Motherboard
Gigabyte Technology Co. Ltd. GA-78LMT-S2 (Socket M2) 39 °C
Graphics
ATI Radeon RX 480 Graphics (XFX Pine Group)
Your motherboard will not support 125w TDP CPUs let alone the 220w needed for 9XXX serries.
At best you could get an 8320E (not sure if they have wrath cooler or not), but even if you did it wont make much difference as 6 weak cores vs 8 weak cores does not matter much when most games will only use 4 anyways.
At this point a modern core i3 with half the cores will beat out the 83xx in most games it has stronger more efficient cores.
Best advise is to save money to upgrade out of AM3/FX and either go intel or AMD RYZEN (AM4) when it comes out
If by 9870 you were meaning to say one of AMDs FX-9xxx CPUs, please don't get one, they are pretty awful.
Upgrading to an FX-83xx is more practical, but I really don't think you'll get enough of a performance boost to justify dumping more money into such an outdated platform.
If you want to upgrade, wait for Ryzen to come out and then get a whole new platform from either Intel or AMD depending on what prices are like.
