will a Coolermaster GX 650w bronze 80 PSU be enough for that rig
maillet
313
8
18,785
hi! i am planing to upgrade my computer soon. was just wondering iff ill get enough power from my coolermaster GX 650w bronze 80 to run this rig well.
CPU: Intel Core i5-6500 Gen6
RAM: 16GB (2x8GB) DDR4 2133MHz
MOBO: GIGABYTE GA-Z170X-Gaming 3
GRAPHICS: Gigabyte GeForce GTX 980Ti
HDD: Seagate Solid State Hybrid Drive
OPTICAL DRIVE: PIONEER DVD-RW DVR-219L
PSU: Cooler Master GX 650 watt bronze 80
4 chasis fans total
1 USB network wifi adapter
1 USB STICK
My main worry is the gtx 980 Ti graphic card
Thanks for your time guys!
it will do the job. But if you can get access to other PSUs I would recommend any from XFX, Superflower, Seasonic.
I wouldn't choose that PSU personally. You can do a lot better, here are some recommendations:
XFX 650w XTR Gold Fully Modular Power Supply Unit
EVGA 650 W G2 GOLD 80+ Modular PC Power Supply Unit
Both of the above PSUs are made by reliable manufacturers and are quality PSUs
It's an okay PSU, the ones I have recommended are in a similar price range and are much more reliable. If you can, I'd avoid it
