yes it’s fine. I would say it will depend on the game and resolution you play. For the most part you will find your graphics card running at 70% or less in game application at 1080p. As long as you are not mining or maxing out the cpu and gpu 24/7 it’s going to be fine.
list all your hardware: CPU, hard drives, fans, extra cards you have installed, etc etc.
Need to know the rest that will draw power since if you only have 1 SSD installed then most likely it will. But if you have 8 - 10 regular HDD`s drives then no.
